Machine monkey said:They do look good. I want... And as i dont like spending monies... I guess i will be cutting mine open over the winter![]()
I'd do mine with you
I tell ya you couldn't write this sh1t!!!
Machine monkey said:That was easy easy p1366 throttle valve adaption. I am sure that's what I had before now time to look through this thread and check.
Put the power on but do not start the engine.
- Floor the throttle for 30-60 seconds
- Keep the throttle to the floor and put the power OFF
- Release the throttle and wait 2 minutes.
Take the throttle body off, and give the butterfly valve a good clean!
I believe there are two on the Z4. The "most common" is located under the intake manifold and is a right arse to get to.
However, the sensors are not THAT expensive, and are more common than a dodgy throttle body
Machine monkey said:Thanks mate.
Its exactly the same problem as before and as i have had one of the same pattern parts fail. I am putting a big leap of faith and £280 quid on the line. Fingers crossed that its this simple.
Machine monkey said:All fixed and running again
Thanks Ian![]()
