Caddyshk said:
Looking forward to programming this. At the last few events I've been trying to drive to avoid DSC intervention but with mixed results.
If you consider the maximum grip that a tyre can yield is explained by the theory of "circle of friction" then you can understand that the DSC will intervene around the point where the loss of traction on the driven wheels under power, coupled with rotation of the car around a vertical axis (i.e yaw) will make the car spin unless the power to the driven wheels is reduced/stopped.
As you know, a tyre has only so much grip that it can give, so braking in a straight line is required when braking from high speed
before a turn, to permit maximum front wheel grip for the direction change, otherwise you get loss of traction, which is experienced as understeer. As you know, it's also possible to use trail braking, where you continue to brake whilst initiating the turn, but because the tyre only has only so much grip it can give, you must apply much reduced braking forces in the turn, so that the tyre can use most of its grip for changing direction.
The same thing applies at the rear wheels with RWD. When the car changes direction at maximum grip levels, continuing to apply full power to the driven wheels whilst it commences to change direction, will exceed grip and this will allow the rear of the car to break free, creating yaw.
The maximum grip of tyres whilst turning requires the tyre to use the maximum slip angle, and the DSC does permit this to happen without intervention, but the sliding feeling that you get when driving at the limit of grip with the car at maximum slip angle of the tyres is not creating yaw, because the car is turning and not rotating.
Therefore, to prevent DSC intervention at maximum grip levels on turns, you need to set the car up so that you get to maximum slip angle without exceeding maximum grip, by lifting off the throttle instantly before you turn, so that the rear wheels can use their maximum grip without power applied, so that 100% of their available grip can act as "brakes" during the initiation of their change of direction. In this scenario, the rear tyres are not being used for traction, and so the rotational speed of the rear wheels can only get slower, so they cannot continue to break traction. Even if they momentarily lose grip during the change of direction, they will soon recover grip. Once the car has become balanced immediately after the change of direction of the whole length of the car, you can reapply the throttle progressively to maintain the speed around the bend and you should then find that you'll be able to feel for maximum grip with maximum slip angle.
I find that by turning sharply off-power into a corner probably 2 metres earlier and not braking as hard as the "slow in, fast out" technique, gets the car to change direction quicker and nicely set up allowing me to reapply power earlier in the turn at higher cornering speeds. At the same time there's no DSC intervention because any yaw that results from lift-off oversteer occurs when there's no power to the rear wheels. Hope this helps.
