T1berious said:Right, the last time it was in was last year and it had an Inspection II 2015 so it's due one. I have done a video and currently looking at decent local indies as I've seen horror stories from main dealers with costs north of 4k.....
Last oil change would be last year. It has always gone to a main dealer.
It is however the dreaded marbles in a can sound while idle and rising in frequency with revs.
I'll pop the video into this once I work out how to upload it!
https://youtu.be/Re2J4Di1QDs
Cheers T1b
T1berious said:Hey Mike,
I'm kind of hoping it will limp home. being nursed gently.
GuidoK said:at what rpm was this video made?
I analyzed the signal with audacity and it turns out that the tick is occuring 9,5 times per second.
So thats roughly 570 per minute.
If the engine is running about 1150rpm its definately valve train related, but if it turns any slower it could be something else.
signal; the tap is clearly visible:
Cheers T1b
How 'cold' is cold start' for an unmodified M?TomK said:Bearing in mind cold start idle is around 1150-1200 and the noise heard you'd have to say it's the cams/followers.
mmm-five said:How 'cold' is cold start' for an unmodified M?TomK said:Bearing in mind cold start idle is around 1150-1200 and the noise heard you'd have to say it's the cams/followers.
Mine cold idled this morning at about 850-900rpm (i.e. after being sat outside for 36 hours)...for the 10 seconds or so that it was immobile of course![]()
But I’d agree with the majority here, and not drive it until it’s checked/fixed, as a £1k bill is much more preferable than having to replace the engine or fully strip/rebuild it.
Z4M-2006 said:It's a forum
All we can do is speculate..
