Made some progress on the electrics over the last couple of weekends.
Started by planning the battery relocation in more detail. The primary wiring goes like this:
Code:
+-----+ __________________ under car to alternator/starter (the really big cable)
| + |/-------[100A]----- under the car to engine power distribution box
| |\-------[250A]----- through the interior (driver's side), across bulkhead, to fuse box
| - |-------- to body earth
Started by removing the battery cables. The pair of under-car cables weigh 2.8kg, the interior one is 2.2kg. And the battery itself, a whopping 19.5kg. Chasing the interior battery cable through the car meant that I had to open up the loom, so I took the opportunity to remove all of the redundant wiring that runs front-to-back. That's the audio, seat power, airbags, and misc stuff like tailgate release and heated rear window. There is still more to come, but the first pass totalled 4.3kg.
It's a nice feeling to chase back the rear wiring (like tailgate open sensor) from the back of the car, all the way to the fusebox. Even better when you can remove entire multi-connectors from the fusebox. Any wire left cut, and possibly carrying a live feed, was capped with heatshrink to avoid shorts.
If I were braver, I would unpick more of the loom now, but it's a time-consuming job and I will take a second pass when I'm ready to put the dash back in.
With the wiring reduced, I moved the OEM battery to the passenger footwell and jerry-rigged the battery cables to pick up the correct fuses. The bulkhead battery post that I fitted previously now connects up to the alternator/starter (unfused). From the same post, I attached the (shortened) engine bay power cable. The 100A fuse that feeds the engine bay power was replaced by a more substantial "mega fuse" of the same rating.
Back in the passenger footwell, the bulkhead post runs straight to the Lithium battery. The little motorcycle battery has tiny terminals, so I used a mega fuse holder (without fuse) to make a beefier terminal with a strip of copper which will make for a decent 'jump start' post if necessary. The battery negative cable will ultimately lead to the isolator (master switch) on the passenger sill, but for now it goes to body at the transmission tunnel.
The last piece of the puzzle is the feed to the fuse box. This uses a 250A fuse connected almost directly to the bulkhead post. Another short length of copper strip was used in preference to a 5cm length of battery cable. Nice and sturdy this way, too.
And it works! The tiny battery struggles a little to get the starter motor moving but then it speeds up and we're away.
Before and after diagrams (so I can remember how it goes!):
I have not weighed all of the new battery cables yet, but we're looking at a saving of 22-23kg. Projected weight is now very close to my 1200kg target.
