lucasxdiniz said:Any plans for the shifter?
What he said. Or are you keeping it as a monument to the car it used to be?
Looks bloody awesome - hope the test goes well.
enuff_zed said:Liam22 said:Yes, the wing is adjustable, but I think I need to drill a few more holes so I can take some more rake off it.Z4C_er said:That is huge!!! Do you have any adjust-ability?
Last of the big jobs was to make a replacement dash panel and fit all the necessary bits and bobs. Took a good few hours to trim it neatly to match the curves of the dash.
After realising I was going to need to keep the heater controls (to bleed water pump) I wanted to hide it, so extended the dash panel down to the transmission tunnel. This turned out to be a convenient place to mount the DSC and Sport buttons.
With the fire extinguisher, battery isolator, and necessary stickers, it now looks like a race car inside and out!
A race car is never "finished" but at this stage we can call it 'ready'![]()
Also seems that I've stretched it out just as the circuits are reopening. Got a test day booked for Snetterton next Thursday!
That's interesting? 3 miles from me! Working from home but could possibly sneak out.
Do you know if they will let others in, just to watch?
It's aluminium composite sheet (3mm thick). Same stuff as I used for the door cards.Vanne said:Dash panel looks really good Liam, and sturdy as hell too i bet. Is it just plate alu?
Liam22 said:My camera died but got a few early laps recorded. Here's one
[youtube]https://youtu.be/toSvQeIOPQ4[/youtube]
Liam22 said:I quite like the OEM shift knob, but it does look a bit pedestrian!
I'm open to suggestions, provided that they use the OEM fitting (no grub screws) and don't add weight.
Had wondered if the BMW Mini (F55) shifter would be a straight swap...
If it arrives :roll:MrPT said:Liam22 said:I quite like the OEM shift knob, but it does look a bit pedestrian!
https://z4-forum.com/forum/viewtopic.php?f=7&t=122399
A classic knob.
Have you checked the sensor plug is connected ok at the bottom of the resevoir?Liam22 said:3. Radiator light comes on frequently, combined with 2E83 code. Ran the water pump bleed cycle a couple of times and topped up, but still there.
