Disca said:Mike46, got some pictures of how they fit and what they look like?
Hello budScooba_Steve said:Just buy the OE LEDs
Led numberplate lights 63.26.7.193.294
Connectors for above 61.13.8.365.340
£25 the lot from Soper
Cheers for that! That would be helpful so I can proceed to orderScooba_Steve said:Hi Bill,
They might be the same as E89, I thought they were off 1 series. Either way that's what I got, they fit perfectly. The only reason for the new connectors is so that the polarity is correct. The old wire pins slip out of the connector with a tiny screwdriver and insert into the new ones.
They certainly don't need cutting off. Does that make sense? I'll dig out the invoice and double check the numbers.
mike46 said:They are the same ones I have fitted, they fit fine. You don't need new connectors though, just cut off the coding. Polarity is correct.
Scooba_Steve said:mike46 said:They are the same ones I have fitted, they fit fine. You don't need new connectors though, just cut off the coding. Polarity is correct.
What do you cut off? A locating pin? The connectors aren't hard to swap and for less than £2 each I didn't want to cut corners.
bradz said:Do the genuine ones fit perfectly?
