Tshirt said:Can anyone recommend a supplier for LED number plate lights, ( complete housing & LED bulbs) that actualy fit properly & work on a 2008 Coupe???
Cheers.
I bought theseTshirt said:Can anyone recommend a supplier for LED number plate lights, ( complete housing & LED bulbs) that actualy fit properly & work on a 2008 Coupe???
Cheers.
Tshirt said:Stupid question, will a LED W5W bulb work if its used in the original holder?
Problem i've got, is the clip has broken in one of the holders. The dam thing hangs down by 5mm on one side.
Do I get a new original part and plug a LED bulb in?
If that works, great. I can then just put an LED bulb in the other one.
Such a small problem causing a headache.
Fed up of buying stuff on line that doesn't work or fit.
Hope someone can advise.
Cheers.
