Breaker said:
Devon-Doug said:
Can you get the diffuser for pre facelift models? To fit it I presume a small section of the bottom rear skirt needs to be cut away?!?!? £295 plus vat seems pretty good given it is real carbon...
I think I want one.
PM cj10jeeper as he fitted one to his pre-facelift.
The OEM diffuser for the prefacelift looks like a ironing board fixed to the underside and it's normally painted to match the body colour as opposed to CF. Not a look I wanted.
The facelift can be made to fit if you are prepared to work at it.
There is no crease line to align with so you need to template it up carefully.
The overall rear shape is identical aside the extreme lower corner edge corners of the lip that have a different profile, so you need to infill the gap in the corners. I used a spare piece of CF that I had from chopping up to fit the quad system.
imho if you are a competent DIY'er do it, ask a bodyshop or leave it.
