Yeah, I think you might have being going the wrong way! I realised that I haven't helped things by quoting "clicks from fully closed" (for the reasons exdos and tertius mention - this is how the manual tells you to adjust them as well). Sorry Phil! :?
Whether it's rebound or bump, "+ve" = harder = more closed = more damped. The easiest way to orient yourself is to think of closing a tap on the top of the damper to firm up rebound, and closing a tap on the bottom of the damper to firm up bump. More bump damping resists the shock compressing. More rebound damping resists it extending.
So by "11/16 rebound" I actually meant five clicks short of the softest setting aka "fully open". You definitely want to be in the softer half of the adjustment range for road driving. At least as a starting point. Recently I've been using "full soft" for long, boring journeys (which would be 1/16 rebound and 1/12 bump using your approach). By most people's standards, e.g. a hungover wife in the passenger seat, it's still a fairly stiff setup.
pHilli0 said:
Fronts: bump 10/16 and rebound 12/16
Rears: bump 11/16 and rebound 13/16
Assuming you are talking about "+ve clicks" here, bump is max 12, so you might end up with an unforgiving front end and an even more understeery car than normal with those settings. Worth experimenting though - so many factors affect oversteer/understeer.
The main traps I've fallen into are trying to sort the ride by fiddling with bump (it
doesn't help it much) instead of rebound (it
does wreck it a lot!) and trying to make the rear more planted by changing the damping. I'm still on stock camber and don't have RTAB limiters, so will try sorting those things next. On a recent NC500 trip the bump steer was frankly a little scary.
For "firm and flat", the defaults seem pretty good to me, which are rebound at 8/16 and bump at 6/12 (front), 5/12 (rear)... clicks from fully closed (+ve) this time!
