pHilli0 said:
do you have any recommendations, I live in the country and I want the best for uneven fast country roads.
I also live in the country and do most of my driving on the twisties. I have KWV3 on my Z3MC and AC Schnitzer Racing suspension on my Z4MC so here's my findings.
For fast road set up you want the suspension to be able to cope with the worst surfaces you'll come across. I've found that on the roads, softer is better than firmer and when you get your set up correct your car will be awesome and give you loads of confidence. And, the ride will also be comfortable. As your starting point, set the front for both bump and rebound to half way from full soft. At the rear, set the bump to 5 from full soft and rebound to 4 from full soft. Give that a try and get used to the way the car feels, then progressively try increasing both the bump and rebound settings at the front, by one click at a time. If you do this, you'll find that you've suddenly gone too firm by one click, which you'll feel through your hands when you go over a noticeable bump in the road. When this happens, back off the bump setting by one click and see how that feels, if it now feels better, try backing off the rebound by one click also, and gauge this. You now know your front settings are somewhere near correct. Then just adjust the front settings to what you like best.
Once you've sorted the front settings, you do the same thing at the rear, by increasing bump and rebound by one click at a time, and keep testing the changes. When you feel that the ride is too firm, soften the rebound setting by one click first and see if that improves things, then try softening the bump by one click. If you go about setting up the suspension by making small changes at one end of the car only, you'll soon hone into the correct set up.
With regard to track set up, you'll find that your fast road settings will work well in the wet, but for the dry settings, because tracks are generally pretty smooth, you can go much nearer to full stiff on both bump and compression all round.
Hope this helps.
