Silva1 said:But he will still require to place the axle in a secure position where it will take most of the weight
I wouldn't work under a car where the axle isn't taking the weight of the engine!
JINGLE said:That's the thing, I have 1 jack and 2 jack stands and I needed it to be high enough for me to get under for 5 mins so did that, hopefully somebody can clarify if it's wrong, if so then where's best for the future![]()
This is exactly what I do (except for wood under the wheels). A bit time consuming, but does the job. I also put a small square bit of wood between the jack and plastic jacking point to protect the plastic from the metal jack. A lot of US owners use a Hockey puck, but as they're not easily found in these parts, I make do with what I havejakblade said:I only have 1 jack Jingle. If you jack up on the rear plastic jacking point you should be able to get high enough to put stand under the front jacking point, then let jack off slowly and repeat for other side. I also usually slip few bits of wood under the rear wheels whilst it's up int'air gives a bit more room.![]()
enzed4 said:This is exactly what I do (except for wood under the wheels). A bit time consuming, but does the job. I also put a small square bit of wood between the jack and plastic jacking point to protect the plastic from the metal jack. A lot of US owners use a Hockey puck, but as they're not easily found in these parts, I make do with what I havejakblade said:I only have 1 jack Jingle. If you jack up on the rear plastic jacking point you should be able to get high enough to put stand under the front jacking point, then let jack off slowly and repeat for other side. I also usually slip few bits of wood under the rear wheels whilst it's up int'air gives a bit more room.![]()
That's the same company that do the disa repair kitJINGLE said:thanks for the comments guys. i would jack up from rear and then put axle stands under front pads but i really dont like the car up that high on the jack as it worries me its gonna fall overmaybe im just being a big girl haha
and when jacking i use 1 of these.... under £3 off ebay and works perfect and just keep it in the box with the jack![]()
http://www.ebay.co.uk/itm/151104545233?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Misterireland said:Hey chap, hope your good. Questions about the shocks and bushes. What was the key indicator that the wishbone bushes were warn? And what told you the shocks were gone or where you lowering regardless? I thought I might try the bushes as a first job... :?
