Issue with roof not comimg up
Reopening the thread the issue came back,
When I press the button to lower the roof, it works normally. However, when I press the button to raise it, I can hear the motor running and the roof moves slightly, but then it stops.
If I assist the roof manually by lifting it a little with my hand, it works. Also, if I don’t lower the roof all the way down but stop it just short of fully closed, it will raise normally. All fluid levels are normal.
Brass button is ok as i can see there is no leak….. i think i stuck with this issue
