enuff_zed said:Hub is easy to swap with the only dodgy bit being the knuckle bolt that clamps the strut. They seize up.
The tie rods would be better replaced, both inner and outer as it’s an easy and fairly cheap job and who knows what state the ball joint is in.
[ref]chengy[/ref], I think he means the lower 'wishbone'. Didn't you just buy a pair of Meyle ones from ECP.pvr said:It is listed as king pin, but have not looked at eBay or anything like that to see if there are cheaper versions of that
pvr said:I bought the drill brush attachments and they worked well when replacing the wheels and cleaning the hubs so they look fine now. The only items on the MOT advisory are on the rear, being rust on the sub frame but not seriously weakened by it.
Weather is good so more of the above on the quickjack 8)
