LukeMace said:pvr said:What is "flash to pass" ?
When you pull back the headlight stick to let someone go. Brings headlights up if lights are on or off![]()
pvr said:LukeMace said:pvr said:What is "flash to pass" ?
Thick moment here, but don't understand. Normally, a flash is the high beam coming on for the duration of the pull. What does it do differently?
I downloaded 7041 by the way.
GreyZed said:LukeMace said:pvr said:What is "flash to pass" ?
Sorry but I don't understand any of that.
Do you mean it flashes dipped beam lamps in addition to high beam? If so this would not be good for any Xenon equipped car.
Also what do you mean by letting someone go? Surely if you are flashing to tell someone to pass you then they are behind you at that point and wouldn't see any lights on the front of your car anyway? I always assumed flash to pass was when you flashed the car in front to let them know you intend to overtake them rather than let them go?
Currently, no.LukeMace said:I may of read the question on here but can't remember or ind the answer -
Can the wipers be set to auto without having to be activated first?
RichardP said:Currently, no.LukeMace said:I may of read the question on here but can't remember or ind the answer -
srhutch said:RichardP said:Currently, no.LukeMace said:I may of read the question on here but can't remember or ind the answer -
It would be dangerous to make them do that. At least it would cause damage to the car in winter if the blades were stuck to the screen.
pvr said:I will check again on my next trip but my last test was as I had driven my entire country lane before indicating for my drive.
Good to know about the 2 seconds rule though, as that would happen on a roundabout going right.
