You don;t need to reset it, but you may want to configure it for your car.ba3bas said:When I got my intravee, I connected it all up and it worked, I set the nav to Mk4 onwards and thats it.
I seem to hear that I probably should have reset the thing???
99% of options can be set via the UI on the monitor, but you may want to update the Intravee firmware to the latest version. See the Intravee forum over on BMW5.co.uk.ba3bas said:How and with what software do you do this and all the other amendments?
That should not be the case, could you give an example. The Nav should not allow you to select an empty menu item.ba3bas said:Also there are blank options on screen when if selected go into menus.
Teraterm is not bundled with the downloader. Teraterm is a simple terminal emulator that can be used to communicate with the Intravee, but you should never need it.
