Bing said:Sorry Jan, mine are buried somewhere. I'll look them out if you remind me. Where did you get it done ?
That sounds really expensive, it would total over £150 quid. Also I don't understand why you pay extra for caster and camber adjustment as that is what you do when you have a wheel alignment. I paid 50 quid for my wheel alignment but I did by two new rears at the same time. Anything over 100 quid sounds excessive and an alignment should include all adjustments to get it right.jampudding said:Any recommendations for wheel alignment in the Kingston Upon Thames area or north surrey/ south london?
Also what do you ask for? Are all these things necessary?
1. Full Geometry - £108.00
2. Steering Sensor Reset - £30.00
3. Individual Camber/Caster adjustment - £15.00
I will ask when I book this but like to be fore-armed if possible.
R3AP4R said:Hi
This is an interesting thread! I had mine done today for £60. `i was shocked because most people pay £100+. Not intending to jack this but also feel that its on topic
So mine was done today as Ive now dropped the car and spaced it 15mm front and 20mm rear. I will post my before and after results later. The car was running well but since the spacers went on, i thought i better get it tracked as the car was shaking at 60 mph +.
1) They listed my 3L as an M, because they said it had M-sport suspension.
2) When I asked about weights they said it would make no difference at the height they tested the car??? this confused me because each time i see a thread on this subject everyone states that weight "must be used" ??
3) My front passenger side wheel goes inwards at the top and is seriously noticeable when on the ramp but not the ground and they advised me to see a mechanic asap, but there was no signs of anything wrong!
4) They advised the camber at rear could not be adjusted as it was at its limit.
5) I know I have a blown front shock, but that was within value but the L was not!?
The statement of being able to get a finger in between the tyre and arch probably relates to having enough travel to avoid rubbing the arches.junglist said:Has anyone had problems with their car being lowered?
The place I use have a Hunter system and charge £45 for front and rear and £15 for any camber adjustments, I've recently lowered mine (Eibach Pro Kit, nothing stupid) and added spacers and wanted to have it done again. Apparently if you can get a finger between the top of the tyre and the arch you should be alright?
See my earlier commentranski said:Kwik fit by me (Sutton Coldfield) have just installed one. Apparently they plan to roll them out across most branches
cj10jeeper said:5 yr revival is worth a commendation
No idea on the perfect response. With my local guys I tell them what I’ve done and they sort my car out, regardless of lowering, shocks, tyres, etc.
