How to- outer CV boot replacement
bigwinn
Elite
 Lincoln UK
Site Supporter
Evening all
Anyone done a write up/how to on this- deffo got a boot thats in need of replacement
Cant find anything immediately on here or via google...
Any advice?
Stuart
You first have to get the drive shaft out of the hub and un bolted from the diff
Good luck you may need it
Or super glue for rubber
Cheers Paul-
I was thinking the lack of info meant it was a cr4p job
I'll have a look see how bad the boot is
Can you buy just the boot?
Getting the shaft out of the hub is the hard bit, I had to give in and get a garage to get mine out, I made it a bit harder by removing the trailing arm/hub from the car.
You may have to remove the rear section of the exhaust to get the drive shaft out.
I have found the boot on Autodoc
I may take it to Andy in Grimsby next time I am there
You need a bi hex socket to get the nut off if in good condition or a good hammer and chisel or an air chisel, if very rusty.
Then a hub puller, I have one in Manchester you can borrow it can be in Cleethorpes in a couple of weeks time.
thanks Paul- you still in Clee from time to time?
I've got a hub puller- I'll get a closer look at the boot tomorrow
Give Simon a call before you get in bits as the auto doc one may or may not work he has plenty of experience of these, hence the puller set up.
Yes in Cleethorpes right now and here till Sunday lunch time then off back to Manchester
Paul I’ve had a closer look the boot seems to be intact
Any ideas on where the gunk is coming from
Stuart
The join between the two metal faces.
You still need to remove the drive shaft to do a good job.
Clean both faces and fit new bolts and plates (BMW) and see what happens
Thanks Paul
