i seem to be getting close to the top of the clutch pedal, no slip, all perfect, but i feel its coming so what does it cost ?
As I say, the pedal engagement point is close to the top these days , are you saying bleeding the clutch will move its engagement point further down the travel?Liam22 said:The clutch is self-adjusting. Pedal travel should not change. If it is, then look at hydraulics first. Bleeding clutch fluid might be a £10 fix.
PDJ said:If there is air in the system you have to compress the air first then push the hydraulic oil along the pipe to operate the clutch so that could well be you issue.
enuff_zed said:PDJ said:If there is air in the system you have to compress the air first then push the hydraulic oil along the pipe to operate the clutch so that could well be you issue.
But would that not cause clutch engagement to be closer to the bottom?
Feck off :rofl:tug said:When i first passed my test, my dad who was a driving instructor back in the day, used to slap my knee if i was riding the clutch.
Perhaps all you need is a f@cking good SLAP!!
Jl-c said:Because BMW put a bit of rubber between two flywheels to take up the shock of dropping the clutch (mainly because the americans can’t drive a manual car ) and this then wears out! :roll:
