How many coupes in the uk
You only need to look at breakers. There seem to be loads of roadsters being broken all the time, but hardly ever a coupe.
earthdweller said:
BTZ461 said:
Hmm reading this as both coupes and roadsters. Given the vagaries of the DVLC and the recording of the variants I'm guessing there is no accurate number available.
There is an accurate record of numbers registered
However, as with the above images it’s just a record of what the DVLA recorded them as, so an Si Sport could be a Coupe or roadster or even a 2.5Si
If you add up all the possible variations and compare with the registration numbers it will give you a ball park
As can be seen from the above a very large number of “Si Sports” have survived … it’s fair to extrapolate that across the other variants
Is there an absolute definitive figure easy to reach … No, but it’s a reasonable assumption to make that a very high proportion have survived as on the example I posted there isn’t a big drop in numbers between 2009 and 2021
Like I said..................... :?
