Flat batteries can be saved.
get yourself a welder firstly.
empty the battery of its juice.
put new acid in.
get a welder, slap it on the contacts a few times
stick battery on charge with a conditioner.
brand new battery.
note: I don't take any responsibility if you spill acid and end up with a hole in your hand or similarly you shock yourself) oh and this method will only work with conventional flooded cells. agm, sealed type batteries can't be fixed in the same way.
Personally, aside from all that hassle, get yourself a Bosch S6 agm battery. Aside from XS Power's D series (stupidly expensive for what is in essence a battery), I would only use Bosch's S6 line. (Again, everyone has their own preference, but I've found the two mentioned brands to be highly reliable)
