jonnywells said:Getting back on topic :roll:
I contacted Chris about the 313 replica wheels. A set with the ET40 would fit the Z4 fine. The fronts would need a 12mm spacer and longer bolts which he can supply and the rears are ET40 as standard.
I was at Odeon leicester last night and i seen an E90 with a set of these on and god they looked good!! Stunning wheels
If the front and rear are both ET40, presumably they are the same width (e89 standard for offset alloys is 8.0 @ ET29 and 8.5 @ ET40), if its 8.0 then you will need spacers on all 4, if they are 8.5 I would be worried that the fronts will rub on lock, if you add a spacer to the front then they might protrude out too far.
