Smartbear said:It’s alloy block & dry sump lubrication system doesn’t compare to the iron block & wet sump of the s54.
srhutch said:Smartbear said:It’s alloy block & dry sump lubrication system doesn’t compare to the iron block & wet sump of the s54.
The S54 is semi dry sump I believe.
No, hence being semi dry not dry...Smartbear said:srhutch said:Smartbear said:It’s alloy block & dry sump lubrication system doesn’t compare to the iron block & wet sump of the s54.
Have they got a remote oil reservoir/filler? :?
Great article.MrPT said:https://jalopnik.com/the-confusing-history-of-the-greatest-v12-bmw-never-bui-1828173674
GuidoK said:And what is a "semi" dry sump?
The only 'somewhat reoccuring' definition I've seen, which also actually has some relevance to both dry sump and normal sump is that 'semi' dry sump has a scavenging pump that pumps the oil coming from the underside of the block to a baffled sump that is located underneath the engine (like a normal sump). So with a scavenging pump like all dry sump systems have but without the external reservoir (like all dry sumps also have)
But the s54 doesn't have a scavenging pump afaik. Or has it?
Thanks, MrPt. Very interesting article.MrPT said:https://jalopnik.com/the-confusing-history-of-the-greatest-v12-bmw-never-bui-1828173674
