Couple of thoughts ....... you mentioned blowing fused/components so it's a voltage surge rather than spike, if voltage surges after the seats have been on for a bit it's probably because they are switching out once warm, the alternator has been producing a high current and is reducing output too slowly, causing a brief surge. I'd have suspected the regulator/alternator, but since you have swapped out the reg' a bad earth or connection (battery, block, alt' or ECU, or seats maybe?)
Chances are surges are occurring with other high draw components like heated glass but not high enough to trip warnings, if so other damaged components will start to pop-up so I wouldn't just leave the seats off and hope TBH.
