Still got an issue, details below if anyone can help!
mjennings23 said:Regulator changed today anyway, not had a chance to properly run it to redline but voltage across battery stayed consistent for the rev range I checked up to 4K so hopefully all is good, was showing a gradual increase beforehand.
Oddly it was a TRW alternator so clearly been replaced at some point, either way the design seems identical to Bosch as the new Bosch regulator was a mirror match to the fitted one.
mjennings23 said:Updates,
Tried a new battery today, no change. Same problem occurring.
Removed, cleaned and reseated engine and battery grounds, both showing resistance when checked as expected, and 0.0v across grounds.
So the next step may indeed be alternator, might pick up a cheap one from ECP for time being, at least that gives the option to return easily if it's not the cause.
The common denominator in all of these tests, however, if that it only happens with the heated seats on. Could this point to a grounding issue on the seat circuit?
mjennings23 said:To clarify, the 18v was read from the OBD port, not a multimeter across the battery.
Ducklakeview said:mjennings23 said:To clarify, the 18v was read from the OBD port, not a multimeter across the battery.
THIS could be the issue. You need to get a decent meter across the battery and see the actual values, not just what the ECU "reports" as if, indeed the voltage is high, then that may also be affecting what the ECU is reporting..
Mike
