How much of the history do you know
What has been changed or checked and when
As above change all the fluids engine oil, coolant, brake fluid, gearbox oil, diff oil, then check the suspension and then all ball joints and control points for wear etc, engine mounts for wear and security, security of all the other mounting brackets for example exhaust hangers etc.
Check all engine ancillary equipment for wear, you could just wait for a failure for example starter motor.
Brake system discs for min thickness pads for wear brake lines etc. Back plates for rust
Then it gets a bit deeper with bearings, wheels, prop shaft, check for wear within the diff.
