sumotan said:Hi Gents,
Is anyone using the above to replace the oem filter for Sdrive28i ?
Pbondar said:General consensus from several forums /articles is that modern air boxes and high quality OE type filters are the way to go.
Several tests have shown little if no real improvement in performance using the K+N type filters and the level of particles passed by these filters is excessive and when associated oil analysis tests have been done show high levels of silicon (ie dirt) in the oil.
I know this flies in the face of 40+ years of K+N marketing but I did have a very good look at this from three different vehicle perspectives and that was the summary data..
So Mahle, Mann, Wix filters come out well..
enuff_zed said:Thanks all, think that may be next on the list then,
sumotan said:Hi Rob thanks again, did you find any improvement in performance like better throttle response ?
Cheers
Smartbear said:sumotan said:Hi Rob thanks again, did you find any improvement in performance like better throttle response ?
Cheers
There was a small improvement of approximately 97bhp, although i did get the car remapped at the same time so it’s difficult to say which produced the largest gain![]()
enuff_zed said:Rob, there has been previous talk about oiled filters messing up the MAF etc.
I can only assume from your comment that this has had no effect on yours.
That aside, after 4 years, do you see any benefit? Would you do it again?
Pbondar said:I did have a very good look at this from three different vehicle perspectives and that was the summary data..
