That's what I'm starting to thinksk93 said:s**t fuel![]()
Thank you for your input, when you say RHS is that when your sat in the car or stood in front of the car, what will I bee looking for on the braided cable?stupot67 said:Hi Lukez4,
The temp gauge dropping when this problem occurs doesn't sound as if this is a fuel problem, more like an intermittent power problem, especially as it's not throwing up any fault codes. A first step would be to check the main feed from the battery to the front of the car and the engine ground return (Low on the RHS of the engine - Braided strap/cable). The ECU's on Zed's seem to be very voltage sensitive and all manor of random issues occur when the voltage is low!
All the best - Let us know how you get on![]()
Stu.
lukez4 said:Thank you for your input, when you say RHS is that when your sat in the car or stood in front of the car, what will I bee looking for on the braided cable?stupot67 said:Hi Lukez4,
Stu.
Sent from my GT-I9505 using Tapatalk
