Help!
Little update, had the codes read last night and was all clear! Strange seems be ok since it first happened
Sent from my GT-I9505 using Tapatalk
Just happened again revs dropped and the temp gauge dropped for 2 seconds then when the light went off it went back to normal, all this happened in about 2 seconds
I'm gonna put some fuel additives in today and take it for a burn to see if that does anything
Hi Lukez4,
The temp gauge dropping when this problem occurs doesn't sound as if this is a fuel problem, more like an intermittent power problem, especially as it's not throwing up any fault codes. A first step would be to check the main feed from the battery to the front of the car and the engine ground return (Low on the RHS of the engine - Braided strap/cable). The ECU's on Zed's seem to be very voltage sensitive and all manor of random issues occur when the voltage is low!
All the best - Let us know how you get on :thumbsup:
Stu.
stupot67 said:
Hi Lukez4,
Stu.
Thank you for your input, when you say RHS is that when your sat in the car or stood in front of the car, what will I bee looking for on the braided cable?
lukez4 said:
stupot67 said:
Hi Lukez4,
Stu.
Hi,
Going from memory a bit here, but I think it is drivers side under the exhaust manifolds, you will be looking to see if it's not come loose where its fixed to the engine and the chassis of the car and not to badly corroded (The cable is tinned copper and looks a silvery green as it weathers).
Stu.
