Help Removing Discs
Lynchy
 North Yorkshire
So I’m replacing discs and pads on my car and for the life of me I can’t get the grub screw out that holds the brake disc in place. Any help would be appreciated :thumbsup:
I've had that once
I got advice to drill a hole in the outer edge of the grub screw, using a small drill to a larger one, to then get a tap into the hole and whack it round with a hammer
Jakg said:
Why can't you get it out? Is it seized or have you rounded it?
It was seized and it has started to round so I stopped. I have decided to drill it out in the morning
bigwinn said:
I've had that once
I assume the grub screw is to just hold the disc in place
Lynchy said:
bigwinn said:
I've had that once
yeah that’s the one
Ive been there a few times!
A good soak overnight in penetrating oil and tackle it with an impact driver.
If this fails, just drill the C/sink head off the holding screw - Once its off, the disc comes away leaving a stub of the screw thread big enough for a set of Mole Grips.
The holding grub screw is usually soft so you shouldn't have any problem and the drill normally centres quite accurately.
Thanks :thumbsup:
bigwinn said:
Lynchy said:
bigwinn said:
I've had that once
yeah that’s the one
Does it matter if the disc doesn’t have a screw as the 5 bolts will hold it in place
If you've started to round it, it's probably a little late unfortunately.
If it's rounded too far, you can use a chisel to tap it round.
Lynchy said:
pvr said:
It is only there so that the disc does not fall off when the wheel is off.
That’s good, I will try to get it out though :wink:
I discovered one that had been sheared and left in the past.
I soon got fed up with the disc moving slightly out of line when I put the wheel on, so the bolts wouldn't go in!
A top tip is to tighten it to break the thread, then loosen.
With any tricky looking bolts I always tighten first because if I round it, I might still be able to remove.
ronk said:
Was there a stub remaining to your mole grips on?
Unfortunately not but I’ll try and drill it out another day as my rear discs came with spare bolts
