longshaw said:
More than Likley wheel speed sensor. If it was handbrake traction and abs then it'll more than Likley be the pump. Think you need to invest in a c101 scanner for about £30 then you can determine the issue
longshaw said:
jamie_z4 said:Think you need to invest in a c101 scanner for about £30 then you can determine the issue
Thank you (Again!)Mr Tidy said:http://bmwfault.codes/
God I hope its not something major ...Zoomer said:Don’t know about the c101 but the C301 tells you the fault. I had the same and it was an ABS SENSOR
Thank you very much. Yes, It certaily will get some much needed TLCHaggisman said:Lovely looking car that I am sure will look better in your ownership.
Hello, ha I agree, great combinationoldgitdave said:Nice looking car & on MV3's too. I think they look great but I am biased
longshaw said:Thank you (Again!)Mr Tidy said:http://bmwfault.codes/
Hey thank you, haha, yeah I'm pretty sure (followed all instructions) and guides online I can find. (very sure the diagnostic was run, it just came back with 0 codes) Also, updated the unit - hoping this might have done the trick. :thumbsdown:Kit Kat said:Hi & welcome. Are you sure you have run diagnostics & not just plugged it in ( sorry not trying to patronise) just checking.![]()
It's going to be even more shiney at the weekend if the rair holds off!Kit Kat said:At least it’s shiny
