Paulwirral said:I learnt on buckets of crap that wouldn't tick over or would stall , think capris escorts and cortinas of the early 80s , it's second nature to the extent of people always comment on it , bike riders especially .
Instead of trying to do it driving quickly when your concentrating on other things do it every time you stop at a junction or lights , pretend your car will cut out when stopping , you will soon get into the habit and then transfer it to driving quickly , it worked for me
Kingash said:I was trying to practice just on the driveway after watching a few vids of the technique and i just can't get my foot in the angles, the throttle is a tad low, maybe I need a plate or something
i used to ride bikes, supermoto's in general and i had no trouble backing them in, a lot easier. I feel better on a bike them in a car tbh
abar121 said:Kingash said:I was trying to practice just on the driveway after watching a few vids of the technique and i just can't get my foot in the angles, the throttle is a tad low, maybe I need a plate or something
I'm also a biker, bit of a two stroke nut.
I just used the throttle cover from something like this:
http://www.ebay.co.uk/itm/ACS-AC-MT-Gas-Brake-Clutch-Pedal-For-BMW-E92-E46-E36-Z3-Z4-M3-M5-M6-E60-E90-/201031721939?hash=item2ece6ca3d3
Where abouts in Essex are you? I'm in East London, happy to meet up one evening, if that helps.
Ed Doe said:As with others I learnt on snotters shortly after passing my test. I had a 106 diesel which didn't strictly require heel and toe but it was pretty damn awkward to manage, so getting the hang of it on that car made it heaps easier in future cars.
I would definitely say the coupe (and therefore all z4s?) pedal box is just cracking for heel and toe - the pedals are perfect spaced, it feels rude not to!![]()
ga41 said:Another picture:
ga41 said:
BMWZ4MC said:ga41 said:
I use the technique on the left in both my ///M and my S2000, but my feet are too big to allow this in my Westfield where I use the technique on the right. I've posted pictures of my throttle pedal modification that solves the poorly spaced pedals in the ///M. I can try to find them again if wanted.
My S2000 pedals are perfectly positioned and the throw of the shifter is really short, which makes for the perfect gear change. BMW could learn a thing or two!
That's a good idea, so might sound stupid is the heel supposed to be under the brake so you pivot to throttle or under the throttle so you pivot to brake?BMWZ4MC said:This is a pedal extension made from the end of a steel rule and a rubber foot. It's trapped under the pedal cover. It can be pivoted up and down to change its height on the pedal to match the prominent border of a shoe and in and out to make it protrude more or less depending on shoe width. When someone else drives my car, I tuck it out of the way so they don't inadvertently stamp on the throttle whilst braking.
