where are you based? Someone on the forum with a cable might be near by?ProfCJJ said:Fingers crossed
Do the lights come on on the heated seat buttons?
clarker63 said:where are you based? Someone on the forum with a cable might be near by?ProfCJJ said:Fingers crossed
ProfCJJ said:… HOWEVER … I seem to have a problem in the K_CAN lines as as soon as I plug the drivers seat in the car starts going crazy with errors all over the place / all can bus related. When I unplug the drivers seat it all stops. So tomorrow I need to do some diagnosing - perhaps a bad connection somewhere. I’m sure I’ll get to the bottom of it.
AnubisZed said:ProfCJJ said:… HOWEVER … I seem to have a problem in the K_CAN lines as as soon as I plug the drivers seat in the car starts going crazy with errors all over the place / all can bus related. When I unplug the drivers seat it all stops. So tomorrow I need to do some diagnosing - perhaps a bad connection somewhere. I’m sure I’ll get to the bottom of it.
Your High and Low canbus lines are crossed over somewhere. Alas it's a trace job unfortuneately. Assuming the seat is 'as-is' then it's either on the seat plug coupler or whereever you tapped into the canbus lines.
AnubisZed said:Have you seen this?.....
https://www.e90post.com/forums/showthread.php?t=480313
Loads of info on there![]()
I found this the worst bit as my version was in german (is there an english one?), and if I recall I was using profiles for e90s.... maybe I didnt have an up to date version... Plus you worry you will brick your modules.ProfCJJ said:Reading up on the NCSExpert stuff needed too![]()
clarker63 said:I found this the worst bit as my version was in german (is there an english one?), and if I recall I was using profiles for e90s.... maybe I didnt have an up to date version... Plus you worry you will brick your modules.ProfCJJ said:Reading up on the NCSExpert stuff needed too![]()
In the end it was OK though.have faith!
ProfCJJ said:car ablaze - a bonus(!)
Quite a bonus. and a massive step forward! hope you have not put your fuse box away if that's the case. I hate that fuse box location with a passion!AnubisZed said:Drivers side should be fuse 46
AnubisZed said:Switch lights going off, I had this on my passenger side, it was the fuse. Drivers side should be fuse 46![]()
