PJRHIGH said:Thanks for that Usel![]()
When stripping the old heated seat - from the under seat pin connector block did come a green/purple, brown and grey wire that ran up to the old seat heated pad (in the base of the car seat). The aftermarket seat pad only has two cables - one red and one black. I’ve wired green/purple to red, and then brown to the black wire. I had then read to follow the grey wire from the pin connector block towards the seat head pad and add a 10k thermistor to it, then from other end of the thermistor find ground. Apparently this is needed so the stock heating buttons get the right messaging back through the grey cable!?!
Would you know if that sounds right? Like I say, the lights come on and just go off. Reading the fault code is says something like ‘open circuit’
Cheers
It sounds like you are along the right tracks, but because there are various wire colours on cars and different retrofit looms, I'm not too sure what your "grey" wire is.
To try to help, the thermistor needs to be connected between the thin 0.35mm2 wire (which is next to the two thicker heating power wires in the underseat connector block ) and earth.
The thermistor wires are those labelled A14 & A3 (one per seat) with the term "NTC" in the wiring diagram:
https://www.keepandshare.com/doc2/119303/z4-retrofit-heated-seats-pdf-339k
My lights flashed, like yours do when I tried a wrong value resistor in place of the thermistor, which should be a 10kohm NTC type.
