Bit of a 1st world problem tbh.
The driver's side heated seat switch bottom green light doesn't work.
So when you select the lowest setting of heat you have no idea if it is actually on or not...............apart from the obvious toasting sensation in the nether regions!
I'm assuming this is simply a bulb/LED failure.
Is it simplest to change the whole switch?
Are they available?
How easy is to to swap it over? If it's a major operation we'll live with it.
Are they available?
