Have a few problems with my newly acquired 2008 Z4.
The heated rear screen does not work light on panel switch does not illuminate when pressed, also the external temperature on the display shows 50c constantly and cannot be reset, although does change from deg C to deg F if reset is pressed. Defrost also not working.
Are all these connected/ a common fault? Have checked fuses and all okay. :|
