Morning all,
I want to remove the fuse for my headlight washers and also fit a not return vale (the wrong way) in the plastic tube that runs from the reservoir to the washers themselves.
My thought process is that I can’t stand the bloody things because of the mess they make on a freshly cleaned car, and It’s a weekend car that I keep very clean anyway.
I thought by fitting a non-return valve I could avoid the need to remove the bumper to address a minor leak that will no longer exist, but still be able to sort in future if the MOT ever reverts to pre 2018 requirements.
So, does anyone now the internal diameter of the feed to to the washers please?
Also, which fuse is it that needs to be pulled to disable the headlight washer pump?
Many thanks
Many thanks
