I've had to replace both inner and outer front tie rods on a couple of cars. Actually very easy to do and guarantees no problems with alignment.Mr Tidy said:I hope some hear helps - I ended up having both track-rods replaced on mine when I got an alignment done as they were seized solid.![]()
The same goes for the eccentric camber bolt and washer on the rear.
It is also worth removing the three bolts that hold the RTAB housing (one at a time) and giving them a slight dab of grease, then try to spray some Plusgas, or similar, between the housing and the bodywork so it can slide more easily for adjustment.
Oh and assuming you don't go to any of the idiots who claim camber cannot be adjusted, whip out the camber pins on the front top mounts too.
