Darkman said:Mine has the sports suspension and I'm ultra carefull over speed bumps, one I don't think its good for the car going fast over them and two it is a close call to say the least (Regulation speed bumps should be 100mm maximum height or so I believe) though I've come across some which are higher in my opinion
IIRC Eibach Sportlines are red (but aren't available for the Z4), but Eibach Proline are black (and are the ones that fit the Z4).mrlozzer said:Could be wrong, but I think Eibach springs are usually red, rather than black....
a11y said:But then many who saw my Z4 (on Eibachs) always commented it appeared lower than comparable Z4s also on Eibachs (and nothing to do with "fat mates"), so perhaps there's a bit of variance as standard...
tomscott said:I have my Z4M lowered and have no problem what so ever.
The M sport sus is lower than the SE, but I seem to think you could spec you car with the sport suspension. But its no way low enough to scrape anything. If anything it should still look like its on stilts.
Quick way to check, whip a wheel off. All the springs have a logo on them mine have H&R near the top of the spring. But are black so look OEM so have a look!
