If you can post some pics with it disassembled, someone might be able to offer an alternative method.ali_b said:I ordered one and test fitted this weekend just gone, if you dont use the collar, you can get the unit down the shaft even furthur, just need to figure a way of securing the gaitor up to the neck of the item ??
After having a number of different knobs, to me it seems that the greatest effect/improvement is by shortening the height.ali_b said:The gear change is great now its shortened throw !
Incompatible said:After having a number of different knobs
I've just used the collar: on mine, it only raised the knob a couple of millimetres...ali_b said:I ordered one and test fitted this weekend just gone, if you dont use the collar, you can get the unit down the shaft even furthur, just need to figure a way of securing the gaitor up to the neck of the item ??
il beat you to the comments lol
Looks like no easy fix to make much of a difference. You could remove some of the base on the collar, but that would only give you an additional 3mm drop or so based on the photo. Any other modifications will require a fair amount of lathe work.ali_b said:Offending collar :
ali_b said:Shunt - How much are the whalen shif machines ?
ali_b said:Does the Whalen push fit or secure with bolts ?
a11y said:Incompatible said:After having a number of different knobs
Must resist the temptation to comment....
:wink:
60mm -10mm = 50mm (+/-) for the inside shaft hole. IIRC the shifter shaft length over the larger diameter base is about 55mm in length. Shortening the collar might not make much of a difference in lowering the height of the knob or removing any bottom gap. Does the knob sit visibly lower on the shaft without the collar? (I know....a11y said:Only just noticed the latest Q on height: combined with the collar, the Richbrook knob plus collar is approx 60mm. The hole where the shaft goes into extends most of the way through the knob, i.e. I'd say the top of the knob is only approx 10mm above the tip of the shaft...
