Simon 3.2M said:I'm near to Bromsgrove.
Mann Auto Services at Tewkesbury. 1/2 mile from Jct 9 of the M5.
Simon 3.2M said:Castrol 75w 140 from ECP![]()
Hello [ref]Simon 3.2M[/ref], did you use the same Castrol 75w 140 grade for gearbox and the diff?Simon 3.2M said:Castrol 75w 140 from ECP![]()
Spaniarduk said:Hello [ref]Simon 3.2M[/ref], did you use the same Castrol 75w 140 grade for gearbox and the diff?Simon 3.2M said:Castrol 75w 140 from ECP![]()
?R60BBA said:Gearbox - Redline MTL 70w-80 GL4 (1.7 litres)
Differential - Castrol Syntrax LSD 75W 140 (1.2 litres)
Spaniarduk said:Is it then...
If you havenāt heard of something then look it up.mcbeee said:I'm trying to find out what fluid to put in the gearbox and diff on my M Roady, I saw the post re
"R60BBA wrote: ā
Wed Aug 15, 2018 6:23 am
Differential - Castrol Syntrax LSD 75W 140 (1.2 litres)"
Never heard of Redline ?? Also , my indy was looking online and everything was pointing toward ATF ..?? I haven't checked with BMW yet but may have to.. they treat me well for some unknown reason, it could be because they like my Interlagos blue M (they don't see too many on Vancouver Island , either that or they think I will trade in my Porker for a new BMW, either way if they want to give me a discount I'll gladly take it)
Anything else I should know about ? ... I do live on an island in the Pacific and good car stuff is not that plentiful here.![]()
Spaniarduk said:What i used for my gearbox and LSD diff
R60BBA said:Spaniarduk said:What i used for my gearbox and LSD diff
Si, pero porque la pregunta?
I agree. However i only noticed it once i had already purchased the oil, which according to it it was the wrong one. I still went ahead and used it. The gear change was much improved after that, so that could only mean what went in does a better job that what came out.PDJ said:The gearbox should have a label on it (yellow or orange) and there is two types of recommended oil for the gearbox depending on which label you have.
Spaniarduk said:R60BBA said:Spaniarduk said:What i used for my gearbox and LSD diff
Pardon?? There is no question (nor a question mark at the end). Those products are "what' I used'. 'What I used' being the subordinate sentence. Sorry I omitted the start. :?
