I have a 2003 3.0i with SMG Transmission. When the gear selector is in neutral the dash shows 1. The car will not start. Shouldn't it be showing N on the dash as well as at the shifter. Has anyone had this problem or solved this before?
Hi there Artman. My SMG very occasionally does this. Make sure the door is shut, ignition off and then back on again, foot on brake pedal and try to move the gear selector to D. Then move it back to N pausing in between moves. Sometimes it takes a couple of goes or even moving across to R and back also.
These photos from the manual may be useful
That does sound a little more serious a problem Artman. Try disconnecting the battery for a while maybe ? Have you got a code reader like a C110 etc ? Any error codes may point you in the right direction ? Also, try getting in touch with SMG Society in Germany. https://www.smgsociety.com/
I've had dealings and purchased parts from them in the past.....they really know their stuff
