Hi Tim, that would be easy to fit a lever type valve there, I found some of those screw driver type isolator valves leak. Has he used PTFE tape on the olive joints ??
It's not needed Tim, PTFE tape is for threaded joints. In a compression joint, the olive is the seal. I normally pull any of our contractors I see using it on compression fittings.
