billy_beemer said:
So someone had to ask, what were the conditions like when you did your MAF tests?
I've noticed they were on different days. It stands to reason a nice cold day would produce much better results through the MAF anyway. Really the logging needs to be performed back to back to get the best results?
It looks like you are getting better results when the intake temperature is lower and air would naturally be more dense........
Billy,
I have a considerable amount of data collected on all this stuff which has been collected over several years now, and obviously the weather conditions have varied quite a bit during that time and when data logging! Obviously, it would be ideal to always do back-to-back testing in the same conditions, and this has been possible when comparing the OEM MAF Screen with the Honeycomb MAF Screen, which I can swap over in just a few minutes at the side of the road. However, with things like swapping gutted silencers or fitting my Ramcharger mods, this is impossible because I need some garage time to do these jobs.
However, from recording the Ambient Air Temperature and Ambient Pressure at the time of the run, it's possible to calculate the difference in air density so that the results can be "standardised" if required. If I use my DashDyno in "Dyno" mode, it's necessary to include temperature, pressure and altitude in the configuration, so the results that it produces are ALWAYS standardised, thus the weather conditions have no influence on the dyne figures it produces, irrespective of whether its boiling hot or freezing cold, so your always comparing apples with apples.
In the graphs I've posted in this thread above, you can see the differences in temperature, and I wrote:
"However, as the graph shows, the Intake Air temperature (IAT) at WOT for my run was 16 degsF lower than yours, so for the purposes of comparison, I think my using your timeline cancels out any differences for denser air that I was getting."
At long last, there's another Z4M owner who is also "into" this stuff, (
H20), who is an engineer, and he is also using a DashDyno on his Z4M and we are presently exchanging data with each other. In time we'll be able to produce a very interesting record of exactly what happens to performance with various mods. I am sure that
H20 will point out to me if there are any errors in my methods or results that I haven't yet spotted.
EDIT
As it happens, both
H20 and I did some data logging yesterday, and by sheer coincidence our respective datalogs showed during 2nd and 3rd gear accelerations, the IATs were the same at 75 degsF, although we were datalogging on different continents! I have merged the data, and you can see the difference between an OEM US spec Z4MR and my Euro spec Z4MC which has several different air-intake and exhaust mods.
