I have fitted a HID kit from carmodshop
https://www.carmodshop.co.uk/product/35w-h10-gas-discharge-xenon-hid-conversion-kit-set-budget-canbus-pro-error-free/
and also led sides
https://www.ebay.co.uk/itm/LED-CAR-BULBS-W5W-T10-501-LIGHT-SIDE-CANBUS-ERROR-FREE-SMD-WEDGE-INTERIOR-LAMP/283521812779?ssPageName=STRK%3AMEBIDX%3AIT&var=584723258631&_trksid=p2057872.m2749.l2649
I have a dash warning light and also the indicator lights (both sides) are powered when the sides are turned on but when the headlights are powered the indicators are not. I checked for errors using Carista and Torque software, both didn't report an error code.
Whilst I was fitting the hid kit I had to move the car (women!) I had already taken one oem bulb out so the warning light was lit on the dash.
I haven't had chance to look at it due to the damm rain. I am thinking that if I go through a process of elimination by firstly swapping the side bulbs back to oem and hope this clears the warning light. If it doesn't connect the oem headlight bulbs and see if this clears the warning light.
Or do I need something like Carly to clear the warning light or code out the check?
Any advice, words of wisdom will be much appreciated.
and also led sides
