Hi all, been away for a while but I see some of the same faces are still around...
Some of you may remember some time ago I posted about my z4 cutting out, well the garage traced the problem back to the DME, and I found a like for like perfect replacement, I assumed it was fixed and posted as such... but unfortunately this didn't solve the problem. Since then I've been able to find another like for like replacement and my z4 has been a driveway ornament for some 5 months now.
I'd love some expert opinions if I may, I've tried to outline as shortly as possible below the series of events:
So now, I’m considering sending it to another specialist for a second look (Crago's in Dartford), and if they conclude the same thing, breaking it.
All opinions are more than welcome, and I salute you if you've read it all. If some good does come out of the helpful wonderfulness of this forum, then I'll be donating some spare parts to members by way of give aways as a thank you.
- On a summer evening drive, flying along quite happy with the roof down the car just cut out. Thankfully it restarted and I thought no more of it, but in the coming weeks it began to do it more and more and be more and more difficult to restart.
- Upon some local recommendations I took the car to Scotts Performance Cars (Biddenden Motorsport) in Dartford.
- They did all manner of checks, I cleared ECU before I gave it to them so it was clean, they test drove it and eventually it cut out etc.
- They diagnosed it as DME (which is ECU) fault. In order to replace this with a second hand unit there are a number of things that need to be replaced, not just the DME.
- It needs to have the DME (with exact matching numbers from a 3.0 manual) and the associated EWS (key ECU box), the key, and the ignition barrel off of the car. After a few weeks of searching I managed to find one and they fitted it. Solved I thought.
- The car fired and didn’t cut out, however it would only run on 5 cylinders, cylinder 3 wasn’t firing at all.
- They tried swapping coils, plugs and whatnot, and it always remained on cylinder 3. So they concluded that the second hand DME I had sourced must have had an inherent fault and I either needed a new DME or to find a different one.
- I returned the one I’d bought for a refund thankfully and I’ve had it recovered home as they didn’t have much space there and I need to transfer insurance etc to the mini.
