exdos said:kerstien said:I received my pedals and am looking forward to Installing them. Funny thing is that when I placed then over the car pedals, the holes in the covers don't all fall within the pedal. It's like they are too large for the car pedals. Are yours the same John?
Kerstien
Exactly the same. What you need to do with the clutch and brake pedals is: remove the OEM rubber covers. Then for each ACS cover, insert a couple of the screws through the top 2 holes and just fasten the nuts on to them very loosely then place the cover onto the appropriate pedal so that the nuts lie on the underside of the pedal. When the cover is in place, put the other two screws through the holes in the cover, and fasten the nuts to them and then tighten them all up. No need to drill any holes. Job done.![]()
For the accelerator pedal. I suggest that you place the cover onto the OEM pedal and position the cover so that the top holes are as high on the OEM pedal as possible but still able to drill a hole in the OEM pedal. Drill one hole at the top and then insert a screw and fasten the cover in place. Wrap some tape around the cover and pedal so that the cover is firmly in place, then use a Dremmel (or similar) to drill holes in the pedal for the other 3 screws, using the cover as the template guide whilst drilling. Putting the nuts onto the screws for the accelerator is very tricky, but I found that sticking a nut onto the end of my index finger with contact adhesive allowed me to feel for the end of the screw via the nut stuck on my finger.
Hope this helps.![]()
Phew I thought I had a problem with mine. Ill try doing it tomorrow but your explanation is very clear so I should manage. Thanks as usual for the solid help.
