do they ? pretty sure my 35iS had a 98 ron sticker on itBusterboo said:BMW and I recommend 95 RON.
:worshipbmw:
:worshipbmw:
Chris_D said:No benefits to be gained whatsoever with anything higher than 95RON, especially if you don’t have a high compression engine.
once again you sure ? as smartbear has mentioned forced iduction engines do and my owners manual makes it clear that engine is designed to run on 99 ron (porsche boxster 718 gts) , it always kind of surprises me , everyone on here has probaly spent many thousands of pounds buying nice cars and then go into meltdown about spending a few quid on petrol
Mine has 95. Honest, Mr.chasBMW said:do they ? pretty sure my 35iS had a 98 ron sticker on itBusterboo said:BMW and I recommend 95 RON.
:worshipbmw:
:worshipbmw:
buzyg said:Chris_D said:No benefits to be gained whatsoever with anything higher than 95RON, especially if you don’t have a high compression engine.
Indeed, do the E89 engines improve their performance on higher Octane petrol? I have know idea just asking..
Certainly the S54 needs it in the E85 M's but what other Z4 engines are designed specifically to run better on the higher Octane fuels?
Busterboo said:OK, I'll admit my 35iS chugs a bit on RON's 95, especially up hills. Mind you, it's only been running on 5 cylinders since last lockdown. But I look at it this way ... 5 is one more than most folk have anyway, so you could say I've still got one spare. And what with the money I've saved on not having the missing one fixed and on only having to 'feed' 5 with petrol instead of 6 and with only using RON's 95, I'm quids in.
warmasice said:buzyg said:Chris_D said:No benefits to be gained whatsoever with anything higher than 95RON, especially if you don’t have a high compression engine.
With a remapped N20, I can confirm higher octane fuel (I use She'll V Power) makes a noticeable difference to performance. 100%.
john-e89 said:R.E92 said:It's nice to have another option aside from just VPower and Momentum but the price makes it useful only as a last resort.
There's no benefit in using higher octane fuel unless tuned though. Both the N20 and N54 engines in their standard state will operate at maximum output on any standard petrol. There's no method by which the engine can produce more power with the increase octane, it can only reduce output when the fuel quality is bad.
Point taken. So what in your opinion or professional opinion is the point of higher octane fuel...? Genuine question, not a sarcastic post as it may seem to be given it’s through a keyboard and not face to face.![]()
Ok I sort of mis-remembered in that it does show 95 as being ok but it does also say that 98 is useable and to my mind it makes sense to use the highest permittedArgyll Andy said:chasBMW said:do they ? pretty sure my 35iS had a 98 ron sticker on itBusterboo said:BMW and I recommend 95 RON.
:worshipbmw:
Just nipped out to check mine after your post because I run on 95 RON
Danglesberries said:What page number in your book does it tell you to run a 330i, N52 engine on 98RON?
My book says it CAN be run on 98 RON although 95 RON is standard and PERFECTLY ACCEPTABLE.
91 RON is the absolute minimum you can use and ONLY IN AN EMERGENCY when nothing else is available.
Mr Tidy said:Here's a copy of the 2005 manual for all petrol E90s - it's on pages 108 & 109 and says to fill up with 98 whenever possible.
Busterboo said:Mr Tidy wrote: ↑Fri Nov 13, 2020 7:46 pm
No, I just drive an E89.Mr Tidy said:Fair enough, you obviously know better than the manufacturer!Busterboo said:Mr Tidy wrote: ↑Fri Nov 13, 2020 7:46 pm
