What he said +1
I remember now I think we have discussed it on another thread
paulgs1000 said:Great post Alun1976 - especially for those of us who will never do such a rebuild - really interested to see the engine stripped down and rebuilt - great to see the internals - thanks for posting - looking forward to seeing more - all the best with it!
Mark-Z4 said:Nice! Those E89 wheels look awesome8)
Beedub said:the car looks AWESOME alun, it reaaaaallly does!! can't believe how much those wheels suit the car, are they reps? 19s? offsets ? tyre sizes??
this is a very special car and unique imo, the engine detail is incredible, don't scrimp on the overall external finish and choose something nice to set it all off and showcase your hardwork. When are you hoping for your first drive??
Sim_Simma said:Mark-Z4 said:Nice! Those E89 wheels look awesome8)
They really do!
Do you intend to deginger the headlights?
Alun1976 said:Sim_Simma said:Mark-Z4 said:Nice! Those E89 wheels look awesome8)
They really do!
Thanks, I wasn't going to bother degingering as I don't really think it would add any worthwhile image to the car, but that's just my opinion. I do think it would look better but not that much better worth spending loads of money on. I'm happy with the looks of the car now after its transformation, the only other worthwhile mod externally now would be the Z4m bonnet but can't justify the price.
Sent from my SM-G900F using Tapatalk
Alun1976 said:
I don't see any possibilties to coat parts in the diff. It's made up of gears and roller bearings. Those are made of hardened (heat treated) steel, maybe nitrated. Coating of parts (I see nitrating/carbonating not as a real coating proces, more like impregnating) is mostly done on parts that have low pressure usage, like normal (slide) bearings. The pressure a roller bearing (or the tooth of a cog) gets is maybe 10.000 times that.Alun1976 said:Machine monkey said:I was looking into getting a spare M3 LSD to strip in down and rebuild with coated internals. I have been led to believe that the coatings massively reduce the frictional losses in the diff, so will be an excellent power upgrade (if its true) since there are up to 15% losses in the drivetrain. The chap at camcoat highly recommended coating the internals of the diff. He said he had done his and it made a massive improvement. Hard to believe just from a one thou thickness of coating, but I'd like to give it a try.
GuidoK said:I don't see any possibilties to coat parts in the diff. It's made up of gears and roller bearings. Those are made of hardened (heat treated) steel, maybe nitrated. Coating of parts (I see nitrating/carbonating not as a real coating proces, more like impregnating) is mostly done on parts that have low pressure usage, like normal (slide) bearings. The pressure a roller bearing (or the tooth of a cog) gets is maybe 10.000 times that.Alun1976 said:Machine monkey said:I was looking into getting a spare M3 LSD to strip in down and rebuild with coated internals. I have been led to believe that the coatings massively reduce the frictional losses in the diff, so will be an excellent power upgrade (if its true) since there are up to 15% losses in the drivetrain. The chap at camcoat highly recommended coating the internals of the diff. He said he had done his and it made a massive improvement. Hard to believe just from a one thou thickness of coating, but I'd like to give it a try.
So they are made up of extremely hard (mostly +60HRC) materials.
Do you still have a pic of your old big end piston rod bearings. I'd like to see how they held up to the power of the ts2 spec.
This is an interesting project.
Did the colder sparkplugs resolve the pulsating igition timing issues at 5-6k rpm on the ts2/ts2+ setup?
Babw said:Very cool build.
With regards to the timing issue, have you had the codes read?
Camshaft sensor and/or TPS could have similar symptoms but the codes should be coincidental. It could possibly be the throttle actuator as well.
