EPS issues?
jamesdi said:
Does anyone know if it is ok to drive the car without the EPS motor installed? I have everything marked up for re-installation anyways.
ECU Testing still have my unit and I need to move my car...
If I recall correctly, there is a ribbon cable which can get ripped/snapped, but I believe this only happens when the whole steering column is removed? I think its called the torque/steering angle sensor?
Can someone please confirm?
Many thanks!
You could always use those wheel dolly things if it's not okay and you just need to move it over on a driveway.
jamesdi said:
Did only the pre-facelift Z4's experience this EPS problem, or does it affect all Z4 models?
I say again: the one I changed was a facelift 2.5si :roll:
