Hi everybody,
A longish post, hoping for a bit of advice...
Epic fail strikes me again....my ideas are far beyond my abilities but I keep having a go....
OK so I bought a stack of upgraded front brake parts...new bosh 330 disks, bosh 330 callipers, hella pagid pads, 330 splash guards, brake lube, blue threadlock, brake cleaner, trolly jack, axle stands, torque wrench, socket set and a smaller torx set.
This all to replace the stock 300mm disk, having fitted a Racechip GTS box...and thinking I might need the extra stopping power. I decided to opt for the app controlled chip because I'm so impetuous and the celric tuning agent garage never responded after a few weeks pre lockdown, and the racechip was doing £100 discount, so made in cheaper than Celtic's remap....I fitted it the night before, and in my limited run to the shops, with a quick nip into the motorway, was fairly pleased.
....Anyway never having attempted to change pads let alone the entire brake set up, and fitting bigger disks, I was sort of prepared for a few hitches....
So I jacked up one side with the trolley jack and a couple of longer pieces of wood underneath the sill to spread the forces, and was then able to place the axle stand; then repeated for the other side., clearly over optimistically thinking I was going to do both sides...
Popped the bonnet and undid the brake fluid reservoir, (why I don't know), took off the drivers wheel, having turned it for best access. Then managed to remove the wheel, the pad clip, the calliper, and then its carrier, the disk, and then the guard.
To remove the calliper i hade to undo the brake pipe by undoing it a little and twisting the calliper around and around until it was off....I hadn't really anticipated that the coupling on the brake pipe wouldn't swivel. Anyway i had a bucket so when it was twisted off it started to drain into it...i sort of thought niavely it might stop after a minute but it just trickled on and on.....hmmm not ideal.
As I removed the 4th bolt from the disk guard it came off. I gave it a spay clean, and then attempted to bolt on the new guard. Unfortunately the last bolt that came didn't seem to tighten properly so I tried puttubg on some blue threadlock and just pushed it in. It seemed that the thread was OK on the bolt so I assumed the female thread was dodgy...wasn't really sure what to do about that one...it was going to be loose with the new guard, and could catch the disk....its a problem.
Decided to press on, so I bolted on the new disk and attempted to fit the carrier back on. Having footered around for 20 mins tring to get the carrier bolts seated with no luck I concluded that the carriers were too small for the 330 disks....could that be the case, or was it my inexperience ?? I just couldn't seem to make it fit....is there a bigger carrier that will fit?
Feeling that I was now screwed, I started backing off the job, and reverting to original....everything went back on reasonably well, certainly the carrier seemed to fit and i was able to make it fit much more easily...also I think i got a the last bolt on the guard half tight, so that was a sort of limited win.
Then found the calliper reinstatement a bit fiddly, but got it one, but then had to redo it again, this time with the re-twisted on brake pipe fitted....i would be better if thee connector coupling turned independently of the pipe!
Once is was on i tried pathetically to get the bakes working....hard when I had lost so much brake fluid, and even harder as I had none to top it up with...pumped the brakes until it was squirting out the bleed valve (by undoing it). But I couldn't get it to firm up...think because the level was below minimum. Did as much as I could, cut my losses, put the wheel back on, lowered and cleaned up.
Basically 4+ hours of messing to be left with a car I can't drive...not ideal, especially as the neighbours were asking what I was up to, what was wrong etc....basically just an out of his depth fool braking the brakes.
So I've now ordered some dot 4 brake fluid, and I'm thinking I need some copper grease for the hub....the pressing issues are now the replacement bolt problem, and the carrier size cluster...
Any advice on my crap approach or issues experienced much appreciated
Thanks,
BG
Thanks,
BG
